Bazooka tube
teammonkeys
Bazooka tube
Post by teammonkeys »
I want to inhence my sound in my Vibe. I been looking and I saw that the Matrix has a Bazooka bass tube as an accessory. Has anyone install one before? I was wondering if the Vibe has preset wiring for the Bazooka tube? Do we have to run the power, ground, and speaker wires? I went to the Toyota Dealer and they said that they have never installed one on a Matrix. Does anyone know?http://www.toyota.com/images/vehicles/m ... fer_lg.jpg
2003 AWD Vibe.Satellite Silver, monotone.Fully Loaded with Machine gun mounted on top accessible via Moon Roof. Just Kidding, i have no gun but I do have a sun/moon roof.Side Airbag with shooting 6 disc changer.ilquikgtx's supercharger installed.
Re: Bazooka tube (teammonkeys)
quote:I want to inhence my sound in my Vibe. I been looking and I saw that the Matrix has a Bazooka bass tube as an accessory. Has anyone install one before? Yes, dozens of people have installed tubes or subs. Browse the Audio and Electronics forum.Here's a place to start http://forums.genvibe.com/zerothread?id=3671quote:I was wondering if the Vibe has preset wiring for the Bazooka tube? Do we have to run the power, ground, and speaker wires? Yes, you will have to wire for it. No car, AFAIK, is pre-wired for aftermarket sound equipment. They are wired for what they have installed out of the factory. No extra wiring.
Re: Bazooka tube (silverawd26)
quote:You did not even know Toyota had them until today or yesterday.I assumed he asked if anyone had installed a bazooka tube in general, NOT specifically the Toyota one. I apologize if I misunderstood what he was asking.
champcaracing
Post by champcaracing »
yes i have the toyota tube in my matrix, i think its about 80-100 watts, amp insibe tube, wiring comes with kit and mounting for our rear floor area. but do order the sub control from crutchfield. i have yet to do so. but should give more sub control. it uses the front speaker for the signal.
Re: Bazooka tube (champcaracing)
The wiring comes wiht the kit, but there's no existing wiring in the car for it, correct?You have to feed lines to the front speaker, no?
champcaracing
Re: Bazooka tube (ragingfish)
the harness that comes with the tube, plugs into the back of the radio the body harness then plugs into that connector completing the set up. the sub USES the front speaker signal, along with the front speakers. so you still retain all your speaker normal, but the sub "piggy backs" the fronts.
teammonkeys
It really sound like the factory did not place any hardness at the rear (trunk area), am I right? Do you have to run the wire yourself from the reat to the head unit?
champcaracing
yes, from the head unit to the sub, not hard.
jgvibe
Post by jgvibe »
Mike, The Bazoka sub has to be spliced into the Vibes wire harnace someware. I downloaded the Matrix sub instalation guide and used it to install my Basslink. Was real easy!
2003 AWD Vibe, SatiliteMoon and tunespower packageMonotone package6 CD disk, Baselink Sub
