Hi All,
We've got a 2003 base Vibe here. It's making growling sounds in "D" and I noticed the engine rocking back and forth when shifting between "R" and "D".
So while there might be other issues, I decided to replace the rear motor mount (and also the front), which I happened to have lying around (from RockAuto that I ordered several years ago). The problem is that after removing the one bolt and two of the nuts, the third nut started spinning freely along with the stud because it just let go on the top side. This nut happens to be one of the ones accessed through a hole in the subframe, so I can't get a nut splitter in there (though I haven't tried, because I'd first have to buy one) or a Dremel tool to cut it off (this I did try).
Any suggestions on how to proceed would be appreciated. Do I need to reomve the through bolt holding the engine and drop the subframe? (How? I have the Haynes book but it's very sketchy on details.) I was also thinking of drilling from the top and using a bolt extractor but that seems inaccessible. Unfortunately I'm on a tight schedule. [I'm looking for a shop to do it but it's a challenge to pick one.]
Thanks!
