Air not blowing at any speed
sexymonkeyninja
Post by sexymonkeyninja »
Hey everyone! First time posting. I have a 2010 Pontiac vibe 2.4L and the air isn't blowing at any speed.
It has done this intermittently but this time it hasn't turned back on at all. I checked all the fuses in the engine compartment and under the dash. It seems like P/N: 82620-12280 shown being replaced in this video [https://www.youtube.com/watch?v=R00YOQjzX0I] is what needs to be replaced. I've seen on other forums here that it was a 40A fuse and I'm wondering if that is the actual part that everyone is talking about. If not, I would like to know where that fuse is. The other part I mentioned before seems like it's going to take me a bit of fixing to remedy the situation and I'd rather not dig into that unless I have to. The A/C was blowing cold before the air stopped pushing through and while it was failing, the air would push harder and softer at times. Sometimes it would really crank out the air and other times it would be weak (cranked all the way up).
I already changed out the blower motor and resistor, just in case anyone was wondering. That didn't fix it. Any help would be greatly appreciated.
If there's any other possible reason besides the blower resistor/motor, or that part [https://www.amazon.com/GENUINE-82620-12 ... B07ZWPQN77] that anyone is aware of, I am all ears. I live down south and it's too hot to live without it.
2010 Pontiac Vibe 2.4L 2WD
Re: Air not blowing at any speed
That part refers to the fusible link holder. I suggest first diagnosing the 40A fusible link itself, which is closer to this part: https://www.ebay.com/itm/392331344462. That's the part for my '07--yours will be similar. Before replacing it, pull it and check it with an ohmmeter.
