To date:
- In 2017, soon after the engine light came on, the GM dealer spent 4 hours on it when replacing the PCM/recall, couldn't find the issue and told me to drive it until it drops (um, yeah, all good until it needs an inspection)
- Replaced the gas cap (online trouble shooting pointed to that as a potential problem/solution - vapor lock when gasing up, etc)
- independent mechanic spent 2 hrs and the code reading was that the VIN could not be found...
- another indepedent mechanic took a shot at it, again no resolution and wonky codes.
Since the light came on, I've personally driven it a large distance across the US, coast-to-coast in Canada a couple times, and would not hesitate to jump in it tomorrow and drive it coast-to-coast again. There is nothing wrong with this car. It's the most reliable versatile vehicle I've owned and I'd really like to find a way to solve this. I appreciate any ideas. (Disconnecting it to pass the inspection is not a solution that will work.) Edited to add: VStability Light came on at same time. No issues there either, but noting cause it came on at same time - and remains on.
