How to adjust light direction?
JackWade
Post by JackWade »
I haven’t looked yet, but are we able to adjust the direction of the headlights? A lot of drivers when I’m passing them from the other direction flash me thinking I have highbeams on. I don’t. I did replace the lights with an after market part on Amazon because there were so fogged up, I’m thinking maybe they’re pointing too much towards the other lane.
2006 1.8 1ZZ-FE Moonstone gray with all options such as Moon & tunes package
Re: How to adjust light direction?
Yes.
Looks like you can only adjust the headlights up or down, not side to side.
There are a number of threads here about this, but sometimes the search tool here isn't as helpful when searching for commonly used words. Sometimes I use google and add in a site: qualifier. do a google search for pontiac vibe headlight adjustment site:forums.genvibe.com
For what its worth, I attached the headlight height adjustment procedure for an 03 Matrix, should be the same as for your 06 Vibe. Other threads here suggest that a #3 phillips works well as an adjustment tool
If your lights really are shining too far to the left, then check to make sure the bulb is fully seated. After that, I guess it might be possible to add some spacers somewhere between the body and the lamp assembly if you really do need to tweak it.
a040001.pdf
(37.14 KiB) Downloaded 373 times
