Matrix Radio in old GA
I just bought a Matrix radio I want to install in my dad's 98 Grand Am.Anyone know, since this radio is made by delphi/delco whoever...if I need an adapter harness to go from GA wiring to radio, or if the harnesses have been relatively consistent the last 5 years or so?His radio has theftlock, and i think 6 speakers, if that makes a difference?
Sub-Vibe-R
Re: Matrix Radio in old GA (ragingfish)
Post by Sub-Vibe-R »
I had a 01 Montana with a Delco unit and I used the same wiring harness in my Vibe. So I presume the wiring harness will be the same as well.
Vibe Rater
Re: Matrix Radio in old GA (Sub-Vibe-R)
Post by Vibe Rater »
It will probably just snap right in. If it won't just snap right in, then it probably won't just snap right in.
drunkenmaxx
Re: Matrix Radio in old GA (Vibe Rater)
Post by drunkenmaxx »
quote:It will probably just snap right in. If it won't just snap right in, then it probably won't just snap right in.that is an excellent theory
meathead333
Post by meathead333 »
quote:It will probably just snap right in. If it won't just snap right in, then it probably won't just snap right in.that was deep.
My myspace.com profile My 73' Bronco Cardomain page
Sub-Vibe-R
Re: Matrix Radio in old GA (meathead333)
The wiring harness should fit, but may be the bracket to screw the radio in hte dash will not fit.
quote:The wiring harness should fit, but may be the bracket to screw the radio in hte dash will not fit.Is it possible to obtain a mounting kit for a matrix radio to go into the GA?Derek -- how did you mount the vibe radio in the kia?
