Warp rotors every 5,000, mi
Bobsvibe
Post by Bobsvibe »
2009 base model. I've had a lot of front end work done. It has that signature steering column rattle as people talk about. I've had front rotors put on in. I have no problem until about a little over 4000 mi and they start pulsing like it's warped and when I come off the expressway it's very bad but I just use the engine to break to slow down to about 40 and then put the brakes on. It's like I said I have no problem when they have new rotors on it for a while. Any help would be great. Thank you!
Yes, I've had different manufacturers of the rotors also
Re: Warp rotors every 5,000, mi
Had an 03 matrix, with a rotor warp problem from the disc calipers not releasing enough, causing overheating. replaced both calipers and its been 100K miles since the last time I replaced the rotors.
Not saying that's what's going on with yours
Another cause could be improper or over torquing the lug nuts
Calipers can be the main cause of rotors going bad. You can check this with a temperature IR gun to see how hot the rotors are. A stuck caliper piston, slide pins, bad pin sealing boots, etc.... Also a bad brake line hose or a pinched steel brake line can cause this same thing to happen too. That is why you should never let a caliper hang by its brake hose. You can damage the hose layers inside the line. The inside layers of the brake hose can then act as a check valve and hold pressure on the caliper and brakes, wrapping the rotor.
You also need to make sure all rust is removed between the hub and the rotor. Good contact here can help get rid of heat from the rotor.
If you have a bad speed sensor or anti-loc brake system part failure could cause issues with wrapping too.
lexicon
Everything you wanted to know about brake judder...
Post by lexicon »
I had brake rotor warp symptoms and ended up replacing my rotors that fixed the issue , but that was before this article.
its a long pdf, but may help w your problem....
https://www.centricparts.com/media/tech ... 2018_1.pdf
2005 VibeAutomaticStockNon AWD125 hp model
GammaFlat
Post by GammaFlat »
Make sure to clean the hub before you seat the rotor. If there's any debris on the hub, it will tilt the rotor. Any rust thicker than fine powder can be a problem that could easily cause pulsing over time.
I just changed rear rotors on my Honda Ridgeline. I noticed that the new rotor "wobbled" as I tried to seat it. The threaded holes that are used to pop the rotor off were in different locations and left telltale rust "crusticles" on the hub. I cleaned them with a flatblade screwdriver (better would have maybe been a wire wheel). That made the rotor seat perfectly!
