07 Vibe 6 speed GT Transmission Issues
Atomana1
Post by Atomana1 »
My 07 Vibe starting pushing me out of 3rd gear at first. I worked my way around it and just bypassed 3rd for a while. Months later it happened to 4th gear. I drove it, shifting from 2nd to 5th for a while. I have it parked for now until I sort out what to do about this transmission. Is a rebuild kit the better option?
Re: 07 Vibe 6 speed GT Transmission Issues
Atomana1 wrote: Tue Dec 27, 2022 6:49 pm Is a rebuild kit the better option?
Too many unknowns here :? Oh, welcome to GenVibe ;)
"Is the rebuild kit the better option, compared to ???? Mileage? How long have you had it? Climate it's usually driven in? How many different drivers use this vehicle? Do you plan on keeping this car for the long haul?
2014 Silverado, 2004 Vibe GT
If it is popping out or will not stay in gear, this is a sign that the synchronizer rings are worn out in the transmission. The only repair at this point is to rebuild the transmission or replace it. The synchro get worn because the engine speed does not match the transmission gear speed when a shift is done. Speed shifting is a great way to take synchro rings out, besides causing other damage to the transmission.
Look up the book value on the car and then how much money you are going to put into it for repairs. That will tell you if it is worth it.
SeattleJeremy
Post by SeattleJeremy »
tpollauf wrote: Tue Dec 27, 2022 7:17 pm
I agree way too many unknowns. Also, Pontiac discontinued the GT/6-speed after model year 2006.
Rebuild or replace the transmission.
salamander162
Post by salamander162 »
hi guys !!
i have same problem but with the 6th gear, it is hard or expensive to replace the synchronizer ring?
and i want to keep this car for the longest, i love manual transmision
