Confused on 06 battery clamp bracket ??
Jackstand347
Post by Jackstand347 »
After months of looking for a vibe i just picket up an 06 with 95,000 I'm good shape!
The bracket to hold down the battery is missing and the pictures I've found online don't look like my car but maybe it's bc I'm not in person but they look like the bracket connects to a hole in the air filter box but the only hole on this car is too far to the left parallel with the battery terminal. here's a picture of my car
Re: Confused on 06 battery clamp bracket ??
Yeah, not quite OEM there. :lol:
Here's what yours is missing.
The front side bolts into the radiator support (10 mm head) and at the rear there's a threaded rod (10mm nut) that hooks into a hole in the left transmission mount.
Hope that helps!
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
Jackstand347
That's exactly what I need to see,
Thank you thank you!
