Need part number for 03 CV Axle Seals
chrispbacon
Post by chrispbacon »
Hi there.
I have a 2003 Pontiac Vibe 2-wheel drive.
I am getting the CV Axles replaced with new ones and was advised to get the CV Axle seals also replaced.
I've called around everywhere and searched online but I can't find it. Can someone please help?
Thanks.
chrispbacon
Re: Need part number for 03 CV Axle Seals
Does anyone know this part number?
You want to confirm this info for yourself before you spend money
one of the online GM parts websites is
https://www.gmpartsgiant.com/oem-pontia ... &filter=()
(I have never used them)
It lists different axle seals, depending on transmission, with RPO codes. for a 2003 two wheel drive, the following RPO codes are applicable
LNK - 2ZZ engine (GT)
LV6 - 1ZZ engine (base/awd)
MK5 - 5-speed manual tranny (also MM5)
MU4 - 4 speed auto tranny
MTN 6 speed manual (GT) (also MN6)
So, according to that web page,
if you have a GT or a base 5 speed manual you'd need
- 19205385 Drivers side
- 19205389 Passenger side
If you have a base with automatic tranny, you'd need
- 88972075 Drivers side
- 94859762 Passenger Side
That website lists the ones for the auto tranny as discontinued parts, but today I see ebay listings for each of those two.
I didn't look for equivalent Toyota Matrix parts, but they may be less expensive if you can identify the toyota part numbers
