vacuum and fuel pressure specifications.
Bookworm
Post by Bookworm »
I'm having a hard time tracking these down. I'm seeing 38-44 PSI for fuel, but zip for what the vacuum should be at idle (to check for vacuum leaks)
Re: vacuum and fuel pressure specifications.
Here, this link may help explain things about engine vacuum: https://www.motor.com/magazine-summary/ ... uum-gauge/
There are so many things that can effect vacuum, like altitude, camshaft timing, exhaust systems, etc... that manufactures have not listed vacuum spec's for decades now.
The 03 Matrix manual (attached) says fuel pressure of 44-50 psi at idle, but I can't find anything about measuring vacuum.
onvein40.pdf
Fuel System - On Vehicle Inspection
(37.02 KiB) Downloaded 123 times
Bookworm
Post by Bookworm »
Automotive engineers (and companies) drive me nuts.
It's another round of "It's a vacuum problem". "Okay, how do you know?" 'we just do'.
Determine vacuum problem: How, measure vacuum at different areas with things blocked off. What's it supposed to be? "Oh, we won't tell you. We just know".
Bookworm
Post by Bookworm »
I think I'll hook up my Mityvac to one of the vacuum lines and use that to give me some pressure readings.
