Fuel Injector - replacement or o-rings?
Bookworm
Post by Bookworm »
The last engine I really did fuel system work upon was a carbureted system.
How does one pull the fuel injectors out? I suspect it's pretty simple, but I'd rather hear it from someone who has done it.
Also, is it better to replace the o-rings before trying to replace the injectors themselves?
BW
Re: Fuel Injector - replacement or o-rings?
Bookworm wrote: Fri Mar 18, 2022 6:21 pm
I have never done it on any car, so you'd rather not hear it from me ;) but I attached the section from the 03 matrix manual on replacing fuel injectors on a 1zz
Looks like the only difficult part is finding something to take the place of special service tool 09268–21010 called out in step 6. Once for a similar connection on a different car, I was able to make something out of the (unused) tip from a caulk tube but I have no idea if that would work here.
Also "Do not bent, fold and rotate the nylon tube." (don't know why I get a kick out of typos)
x040001.pdf
03 1ZZ Fuel Injector R&R Procedure
(108.95 KiB) Downloaded 5563 times
It's a pretty straightforward task. You can probably get away with just unbolting all of the hold downs for the fuel rail there and then lift it out of the way to replace the injectors...It's been a while, but I am pretty sure that's what we did when we swapped the blown motor.
Bookworm
Post by Bookworm »
Thanks. I'm going to update the P0171 thread, but I'm getting really frustrated.
