Quarts required to fill 2003 six speed manual
owboky
Post by owboky »
Swapped out my 5-speed for 6-speed need to know how many quarts is required to refill
Re: Quarts required to fill 2003 six speed manual
FYI, if you don't have an owners manual, you can download a PDF of it here at
https://forums.genvibe.com/phpBB3/viewtopic.php?t=755
Page 6-76 of the 2003 owners manual says the transaxle capacities are
Automatic Transaxle
1.8L Engine (Code 8) . . . . . . . . . 3.3 quarts (3.1 L)
with AWD . . . . . . . . . . . . . . . . . . 3.1 quarts (2.9 L)
Manual Transaxle
Five-Speed . . . . . . . . . . . . . . . . . 2.0 quarts (1.9 L)
Six-Speed . . . . . . . . . . . . . . . . . . 2.4 quarts (2.3 L)
so 2.4 quarts (2.3 L)
Also, on page 6-28, it says
How to Add Fluid
Here’s how to add fluid. Refer to the Maintenance
Schedule to determine what kind of fluid to use. See
“Recommended Fluids and Lubricants” in the Index.
1. Remove the filler plug.
2. Add fluid at the filler plug hole. Add only enough
fluid to bring the fluid level up to the bottom of the
filler plug hole.
3. Install the filler plug. Be sure the plug is fully seated.
