5 speed manual transmission
owboky
Post by owboky »
Will a 2002 Toyota Corolla 5 speed manual transmission swap into a 5-speed manual 2008 Pontiac Vibe?
Re: 5 speed manual transmission
yes
it might, however, I am concerned by two things:
2003 Vibe 5 speeds seem to be prone to bearing failures, which 02 corollas didn't, so that makes me think there was a change between the 02 and the 03 trannies
car-part.com is an online tool to search junkyards for parts, and they tie in to some standard interchangeability reference. A search for 02 corolla 5 speed trannies yields nothing newer than 2002, and a search for an 03 Vibe yields nothing older than 2003. I interpret this to mean that the 02 and older are not interchangeable with the 03 and newer.
So, it might be, but if it were me I wouldn't chance it.
SeattleJeremy
Post by SeattleJeremy »
The 2002 and 2003 transmissions are likely different in some way.
However, the Corolla 2003 5-speeds don't fail at the same rate as the Vibe/Matrix. I think we determined the transmissions are the same and the heavier Vibe/Matrix 5-speed fails due to the extra weight of the cars.
