I looked around online and inside the engine compartment. I found a post about a grommet in the firewall with a lot of wires passing through it. The post was about pulling a wire into the engine compartment for an amp:
Code: Select all
https://forums.genvibe.com/phpBB3/viewtopic.php?t=38853
They posted a labeled picture showing the location and an enlargement showing the grommet and wire bundle. I could see a blue wire with a red stripe in the upper right of that picture.
I also took a picture of my engine fuse box. The diagram doesn't totally match up with the real fuse box, but it looks like I have the AMP fuse in place. Sadly, my MAYDAY fuse is blank.
I've attached all of these pictures.
I think I have and can use a tone generator to make sure this is the wire and maybe locate it on the other side if I can find it.
- enginefuseboxdiagramw_pictureofbox.resized.resized.resized.png (257.51 KiB) Viewed 3843 times
