Replacing Lower Control Arms - with what parts?
LaiFong
Post by LaiFong »
Super simple, practical questions here.
Both front lower control arms and the engine cradle/subframe/crossmember on my 07 Pontiac Vibe need to be replaced. What are all the parts I need to source? I know a few of them, but maybe not all...I'm excited to get my Vibe going strong again, just want to click Place order!
Questions and what's in my cart at Rockauto so far:
1.Are the not included "Grease fittings" and "mounting hardware" for the arms needed? If so exactly what grease fitting and mounting hardware? Can't find any info.
2.Other parts for the cradle?
3.Front Right Lower Control Arm ACDELCO 45D3232
4.Front Left Lower Control Arm ACDELCO 45D3231
5.Ball Joint GM GENUINE 19184280
6. Not from Rockauto - used 2005 Vibe engine cradle from a salvage place
Arms:
(Pre Greased No
Bushings Included Yes
Mounting Hardware Included No
Grease Fitting Included No
Bushing Color Black
Ball Joint Included No
Ball Joint:
Adjustable No
Castle Nut Included Yes
Cotter Pin Hole Yes
Dust Boot Yes
Greasable No
Mounting Hole Quantity 3
Stud Thread Diameter 0.55 IN
Stud Type Threaded
Thank you!
Re: Replacing Lower Control Arms - with what parts?
ball joint unbolts from the arm. unless the ball joint is bad, i'd leave it alone.
i'm surprised the engine cradle is bad...they're usually fine unless you hit something lol.
LaiFong
Post by LaiFong »
Thanks.
Well something did hit the car. It was pushed 8 feet back and up onto the sidewalk, and the cradle bent where it was rusted. Not so lol.
cptnsolo77
Post by cptnsolo77 »
I did the lower control arms myself. I didnt enjoy that job one bit :lol:
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
