Good fixing chemicals/ideas for vibrations....
cbusenke
Post by cbusenke »
I've got a 2004 Vibe, base model, the car is still kicking (removed) at around 400k miles. However, the dash has been opened up, Often. It's been a real pain in the (removed) to find out where the cables to the a/c system attach to the back of the dials. More than that, I'd really like some ideas on what I could put in between pieces of plastic in the same module or in between the clear lenses that cover the gauges on the dash panel and the silver framing around them. If you've taken it apart you know what I mean
Cbusenke
Cbusen@yahoo.com
Sorry if I'm slow to reply to email, posting on here is prob best
SSizler
Re: Good fixing chemicals/ideas for vibrations....
Post by SSizler »
I got a OEM Toyota noise kit, PN: 08231-00801
It has some handy adhesive backed foam and felt sheets that solve many rattle problems.
Here is a link with a photo:
http://www.2040-parts.com/genuine-oem-t ... --i687928/
Good luck!
06 AWD/Abyss Black Mono/Loaded/Spoilers/Ground effects/172k/ 2025 Vibestock "Most Bling" Award
06 AWD/Lava Red Mono/Loaded/Spoilers/Ground effects/Leather/150k
05 Base/ Lava Red/ Daughters Car
06 Base/Gray/Totaled 5-24
03 Base/White/Totaled 1-23
