Question about Vibe bumpers
ReedWolf
Post by ReedWolf »
can you put an 05-08 bottom bumper cover on a 03-04 top bumper cover? basically im asking if you can mix and match bumps together, if not, any bumpers can you recommend?
Re: Question about Vibe bumpers
No you cannot as the 03/04 is one solid piece, and the 05-08 I believe is one solid piece. The whole bumper covers themselves are interchangeable, however, you would also need to grab the crash foam behind whatever one you are going to use. The crash foam fits in each style cover slightly different so it needs to be swapped.
