2003 ticking in dashboard
fuzzymaster
Post by fuzzymaster »
I had this problem before and I change a prt out and fixed it, but before the ticking would stop by pushing circ button. Nothing stops the ticking this time. Still same problem? And what part needs replaced? Thanks
Re: 2003 ticking in dashboard
Yes, same problem - replace the recirculate door actuator.
They seem to have different failure modes. Ours is on #3... First time, it clicked until you toggled recircuate. Second time, it made no noise but wouldn't move the door at all. #3 is starting to click as well in either position (only clicks once or twice so far,) so I suspect it's going to click non-stop when it finally goes.
It's a garbage part, replace it and call it a day. Or split it apart and flip the gears around. I always replace it with a new one since it's so difficult to change out.
This is the actuator:
https://www.rockauto.com/en/moreinfo.ph ... 57&jsn=398
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
Bookworm
Post by Bookworm »
ColonelPanic wrote: Fri Dec 13, 2019 11:53 am Yes, same problem - replace the recirculate door actuator.
What I did was buy a new one, install it, then swapped the gear in the old one and put it on the shelf. When the "new" one did the same thing, I put the 'flipped' one in, because I could do that immediately, then ordered another (while flipping the gear in the one I'd just pulled)
