2009 wheel fitment question
pwyu1969
Post by pwyu1969 »
I have a 2009 2.4L and I guess the factory wheel specs are 5x114.3, center bore 60mm and backspace of 5.25in. I got some used snow tires that came on Steelies that are 5x114.3, center bore 63mm and backspace of 5.5in. I put them on and the cone-lugs seated and centered fine. No rubbing of brake calipers or anything. So does that mean I’m good to go? Any issues? How tight are specs on wheel fitment? Thanks.
Re: 2009 wheel fitment question
So long as you are not rubbing on anything, you should be fine.
