2005 c/v reoair quesrtion=-
jamesmetairie
Post by jamesmetairie »
we,re on a second vibe.
also we have a 2005 corolla.
the inner , drivers side boot is busted on the corolla.
My very good mechanic had the car on jack stands. he could not get leverage enough on the pry bar to get the c/v end knuckle to back out of the tranny.
he said maybe at a shop , up on a rack it may be possible.
any of you guys ever had trouble getting the shaft out?
is it perhaps possible to cut the shaft to make more room and then replace it with a whole new shaft???
thanks for any advice.
Re: 2005 c/v reoair quesrtion=-
According to the service manual, a slide hammer with a hook attachment should be used: https://www.amazon.com/OTC-6541-Slide-H ... B000RGLX9E
try rotating the axle. the circlip in the trans needs to be more-or-less centered for alignment and it'll fall right out. if it's an OEM axle, you should also have a decent lip that you can put a pry bar against and use a 5lbs sledge to beat it out.
jamesmetairie
thank you to=
and also zbyers
your reply was appreciated.
jamesmetairie
I'm assuming that means you succeeded! :D
jamesmetairie
I brought it to the most highly recommended tranny shop in this area.
they said it was going to be no problem.
they installed a Chinese c/v , but said they never have one return.
thanks again to all .
cptnsolo77
Post by cptnsolo77 »
How much did it cost ?
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
jamesmetairie
the part and labor was about $270.
my original idea was to reboot the existing oem c/v. but the shop strongly advised against that idea.
unfortunately i my have a bad new c/v. from the get-go i could hear a humming noise starting around 30 mph. at 65 to 70 it is very pronounced.
i rotated tires and balanced the front and the noise is still there.
i ordered a set of walmart "westlake " for $35. each. arriving soon. we,ll see then.
on our ,05 vibe we,re running b.f.goodrich from sam,s club.
they,re built with alot of rubber, but the compromise is a ride with some noise and rides rough, not smooth.
