Grounding points
cptnsolo77
Grounding points
Post by cptnsolo77 »
Long story short, I went through 2 alternators but they both dont seem to put out the proper voltage with ALL the accessories on ( 13.5V) I used to get high 13V - 14.1 with everything on. When im stopped at a traffic light it drops to 12.7V. Im suspecting a bad ground. Battery terminals are clean but im looking for a diagram of ALL the grounding points, Cant seem to find anything online for some reason :roll:
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
Re: Grounding points
The attached pdf for an 03 Matrix supposedly shows ground points in triangles. I have a hard time spatially relating these 2D diagrams to the 3d physical car, but maybe it will help
connecto.pdf
(341.02 KiB) Downloaded 1727 times
cptnsolo77
Oh wow ! thanks ! that is EXACTLY what I needed 8-) Hopefully its a simple issue to solve.
Bookworm
Post by Bookworm »
Be sure to check the starter connections.
cptnsolo77
Will do 8-)
