WTB 03 Brake Backing Plate
03GTMatthew
Post by 03GTMatthew »
Hello everyone,
I need the brake backing plates for 2003 Vibe GT rear left and right.
I had the same issue as "Mozilla2ZZ" had in this post.
viewtopic.php?f=26&t=46608&p=522390&hil ... 03#p522390
My hub was rust welded to the backing plate and even with a puller it didn't let go, and it slightly bent the backing plate.
I haven't started on the left side so I'm not sure if I'll need a new one yet.
I can't believe the backing plate is ~$266.21
https://www.carid.com/acdelco/gm-origin ... 9#warranty
At the moment I'm hoping to find an alternative new part.
Located in SW Wisconsin.
Re: WTB 03 Brake Backing Plate
FWIW, Toyota P/N's: Passenger Rear XRS: 46503-20070. Driver's Rear XRS: 46504-20070.
Dad had a simliar issue with his 09 AWD, and we found them through a Canadian dealer for $50 instead of the $200ish they wanted in the US.
The Celica GTS (99-06) or Corolla XRS (I think those were 05-06 only) share the same rear backing plates. that can help widen the search for you.
