OBDII
ktm500mx
OBDII
Post by ktm500mx »
I have a 2009 Pontiac Vibe GT 2.4L with 216K on the clock
went to inspection pass for everything but a OBDII communication
error put my machine on it which is a handheld unit and no
communications at all. Check no voltage at port I am get some
signals. so far no blown fuses. the car has been great so far
but this has me scratching my head.
Any thoughts appreciated.
Mike
hogdoctor
Re: OBDII
Post by hogdoctor »
Find the wiring diagram and take it wire by wire... socket terminal #16 supposed to have power, follow it upstream until you find out where the problem is. Confirm all your grounds too while you're there (terminals 4 and 5) https://components101.com/sites/default ... Pinout.png
Re: OBDII
Pin #16 is +volts and should be a green wire, while pin #4 is ground and should be a white wire with a black stripe. Be very careful measuring the voltage at the plug as shorting the wrong pins together can do major damage to electrical components and be very costly.
ktm500mx
Re: OBDII
Post by ktm500mx »
thanks for the information I will post my findings
thx MIke
Re: OBDII
I know you said no blown fuse, but I'd try to throw a new fuse into whichever one is for the cig lighter in the dash. OBD typically draws power from that same fuse.
