Driver's Side Mirror
Soulmanvibe
Post by Soulmanvibe »
Has anyone had trouble with the driver's side mirror not responding to the mirror controls? My passenger side mirror moves, but the driver's doesn't. I got another mirror at a wrecker and plugged it in, but it didn't work either. Not a big problem, really, but I'm curious what might be wrong.
Re: Driver's Side Mirror
Your second guess should be that the switch is bad but it could be a broken wire or bad connection too. If the salvage yard had a mirror, go back and get the switch to try. If you like to gamble then get the switch.
Soulmanvibe
I went back to the wrecker and got the switch (only a couple of bucks) and it didn't work either. I'm going to check the wires and see if there is anything obviously wrong. I'd appreciate any other ideas.
Soulmanvibe wrote:I went back to the wrecker and got the switch (only a couple of bucks) and it didn't work either. I'm going to check the wires and see if there is anything obviously wrong. I'd appreciate any other ideas.
Check the wires as you have already planned. Keep in mind that the circuit needs to have ground to complete.
If you had used the "Search" box in the upper right side of every page, you would have found this post which has the wiring for the outside mirrors:
viewtopic.php?f=18&t=46061&p=518847&hil ... ng#p518847
You did not say what year Vibe you have but the above wiring diagram is basically the same for the two generations of Vibes. The wire colors are different but where the wires go and how they work are the same.
