edit
mickybluesb
edit
Post by mickybluesb »
edit
Re: I am a Vibe AWD noob,
Definitely clean the MAF sensor. Get the right cleaner and follow instructions you can find online. It's an easy tune-up item. I did mine a few weeks ago and as I recall I only needed a screwdriver to get it out and it took a few minutes.
Also run some fuel injector cleaner, like BG-44K or Seafoam. It might actually be fuel-starved.
Replace the PCV valve too, another easy tune-up item.
Hopefully those will solve the power problem. Some here have modified the air intake and there are a few recent threads about it, and sometimes the MAF gets messed up I think. I'm a noob here too so I can't help too much. And I'm not going for your prize, no way.
I'm not familiar with the Vibe AWD, but I doubt your idea is feasible. You may really mess up the transaxle inputs. Edit: I just did a little research and found out the AWD has a viscous coupling rear differential, so it may indeed be possible to disconnect the rear axle.
Check tire condition and pressures, maybe over-inflate a little (36 psi) to help with fuel economy.
Are you good with pulling dash trim? That's probably what you'll need to do to fix the lighter. I found this link here, helpful for some repairs: http://madstyle1972.com/Repair/
If the temp gauge stays steady within the normal range and the cabin heat is good, the thermostat is probably okay. Mine runs just below middle all the time. That depends so much on the tolerance of factory resistors, etc. If I suspected a problem, I'd use my non-contact infrared thermometer to check the actual engine block temp at the sensor at the water pump.
Can you tell the condition of the coolant? Do you have the orange GM stuff in there? If it's time to change it, you can replace the thermostat then. Get a high quality OEM part.
Welcome to GenVibe! Unfortunately, I'm of no help because I'm not too familiar with the 1st gens (03-08) or AWDs. I'm sure some 1st gen and/or AWD owners will chime in any time now though. I'll definitely be keeping an eye out for pictures of your "new" Vibe ;)!
mickybluesb
edit
sometimes it can be hard to search here, especially if its for common or frequently used terms. I have sometimes resorted to doing a google search of genvibe, using a search string that ends with site:genvibe.com
1 The 03 AWD was rated at 123 HP, the nonAWD base at 130 HP, not that much of a difference. One main thing attributed to cause the difference was that the exhaust on the AWD was more convoluted to work around the rear driveshaft and differential. One member (pmh013) had a lot of power and economy problems with her 03 AWD from catalytic converter clogging, so thats something you might consider checking. I don't remember anyone here having any real benefit from an ecu tweaking chip.
2. Removing the driveshaft might help some, but I don't know if it would help enough to be worth it, especially if you'll be putting it on and off depending on when you might actually want to have a functional AWD
3/4 Some people have put a cold air intake on their vibe, replaces the air box with an open air filter, and they say it helps, but I've never done it.
5 Any chain auto parts store will sell something marketed as a MAF sensor cleaner. Its easy to do, 2 phillips screws and one connector to remove the MAF, then spray the crap out of it with the cleaner, let it dry and put it back in.
6 The smaller gas tank (11 vs 13.2) on the AWD is also due to having to accomodate the rear drive parts, I'm not sure its feasible to try to put a bigger gas tank in there. Easier to carry around a gas can.
7 sounds like you got that one. I had a lot of trouble with that outlet in my first vibe, blew the CIG fuse regularly.
8 Like andewclaus, it sounds like your temp gauge settles about where mine does. Vibes came form the factory with Toyota red coolant
mickybluesb wrote:EVERY TIME i get gas, the car refuses to start for a good 5-10 seconds of the engine turning over before it starts up. I suspect fuel pump? Someone told me it could be fuel pressure regulator? Its as if the pressure in the tank gets released and it has no pressure in the fuel lines to start the car
The car has an electric fuel pump, and I'm pretty sure it powers up when the key is switched to the run position, doesn't need the engine to be actually turning over. Also, in general, the car tries to put a vacuum on the gas tank, not pressure, for evaporative emissions control, so if you hear an air movement sound when you take the gas cap off, its air rushing into the tank, not pressure being released. Have you tried turning the key to run and waiting 5-10 seconds before kicking it to start?
Coolharts
Post by Coolharts »
The AWD Vibe is not a powerhouse and never has been. I have 258,000 on mine and we have owned it since new.
The AWD system is a mechanical connection between the front and rear wheels. The AWD is actually 4WD, always engaged. The drive shaft is a 2 piece unit that connects to the rear axle and as stated before uses the viscous coupling in the rear hogs head, two drive axles come out of the hogs head. As for disconnecting it you will have to remove the drive shaft and plug the transfer case AND rear axle hogs head to prevent leaking.
Modifying the air box improperly will allow dirt into the engine.
On the plus side the AWD VIbe is a snow monster, it will go through 10-12" when other cars are stuck. The production numbers of AWD Vibes is low compared to FWD, also many of the parts are completely different from O2 sensors to the configuration of the throttle body.
The AWD Vibes are in demand, if you want a FWD car sell it, pocket the cash and buy a FWD car, changing everything over will be very intensive and may have unexpected results.
ehoff121
Post by ehoff121 »
Coolharts wrote:The AWD system is a mechanical connection between the front and rear wheels. The AWD is actually 4WD, always engaged. The drive shaft is a 2 piece unit that connects to the rear axle and as stated before uses the viscous coupling in the rear hogs head, two drive axles come out of the hogs head. As for disconnecting it you will have to remove the drive shaft and plug the transfer case AND rear axle hogs head to prevent leaking.
Just to add a clarification to that: the AWD is always connected via the drive shaft, but the viscous coupling in the rear differential engages the rear axles only when the front wheels slip. Also, there is little chance of leakage from the rear diff by disconnecting the drive shaft as it is just 4 bolts to the viscous coupling and there is no gear oil circulating around the coupling thanks to the oil seal behind it. Leaks from the rear axle seals are a different matter... ;)
Coolharts
Post by Coolharts »
Yes, the AWD is always connected but runs at a 70/30 in normal driving, it is always in AWD mode, I have actually spun the rear wheels on mine and the front pulled it, kind of a weird feeling having the back wheels spinning in the snow. I drove through 12 inches of snow a couple of weeks ago and I felt the AWD do all sorts of things.
I had the drive shaft out of mine this weekend to replace the transfer case seal. Fluid does leak from the rear end when the drive shaft is out. BTW, that drive shaft is heavy.
ehoff121
Post by ehoff121 »
Coolharts wrote:I had the drive shaft out of mine this weekend to replace the transfer case seal. Fluid does leak from the rear end when the drive shaft is out. BTW, that drive shaft is heavy.
Assuming we are both talking about 1st gen AWD, there should be no fluid at the connection point of the drive shaft to the viscous coupling. If there is, there's either a missing/leaky oil seal behind the VC or maybe you removed the drive shaft with the viscous coupling still attached. When I removed mine, I disconnected it from the VC (4 bolts), then removed the VC & cover (also 4 bolts); there was fluid behind the VC shaft from the rear diff housing and it will spill if you aren't expecting it. :D
Coolharts
Post by Coolharts »
It is a Gen 1 Vibe. The rear bearings in the diff were replaced about 3 years ago (80,000 miles) and ever since I religiously change the diff oil, it is never low. Yes, when I pulled the shaft there was a trickle of oil that came out but the way the shaft attaches it will be hard for fluid to get past the mounting flange of the shaft.
Coolharts
Post by Coolharts »
In my gravel drive last night I hit the gas hard and the rear wheels kicked gravel, before the front wheels engaged.
