mix 2 kinds coolant=-
jamesmetairie
Post by jamesmetairie »
05 base vibe.
just over 100,000 miles.
coolant was low.
i assume it is original coolant in vibe,couldn,r figure the color.
i topped it with prestone any/kind, anycolor.
i,ve fully replaced old dexcool in my 98 lumina with prestone with no problems.
am i safe in assuming it,ll be good for topping off in the vibe
thanks for any advice.
ehoff121
Re: mix 2 kinds coolant=-
Post by ehoff121 »
The factory fill was Toyota Long Life and was pink.
Was the Prestone 50/50 pre-mixed? I'd be more concerned about the ratio of coolant to water (and might even add distilled water instead since there's not a lot of freezing going on in New Orleans... :D )
Many have done a flush with distilled water, then refilled with either Toyota pink or Xerex Asian.
The Xerex Asian, like the OEM Toyota Super Long Life Coolant that came in your car are non Borate, non Silicate formulas. I'd stick with that. Even if your local store doesn't carry Xerex Asian, I have seen other brands labeled as "Toyota Pink" formula sold in stores. My local parts store as well as my Sears Auto Center had no issues in ordering up Xerex Asian for me at no additional charge. It is sold at a good price and is out there to be had. It just isn't readily stocked at Walmart and most auto parts stores like Pep Boys.
petervivian
Post by petervivian »
In case someone changed the coolant , you can twist the radiator petcock and drain a little bit of the coolant to verify it.
The original coolant should be toyota super long life. They are around 20-30 dollars at dealers. As caretaker has mentioned, other brand coolant with comparable contents costs much less.
10vibe
Post by 10vibe »
What Caretaker said. :D
https://www.valvoline.com/our-products/ ... ze-coolant
Both in red (pinkish) or blue dye packs. Napa usually carries Zerex Asian. Oreilley's sometimes stocks it.
https://www.walmart.com/ip/Zerex-675130 ... /144057949
https://www.walmart.com/ip/Valvoline-As ... n/49660461
I have seen this stocked at a Walmart store. Probably the same as zerex, but possibly the blue dye packs.
Customer questions at the bottom of the page talks about it. A customer review makes it sound like it is pink though.
2010 Vibe 1.8 auto, fwd, base, air, preferred package, cargo mgt, cargo cover, ultra white.
As ehoff121 referred to, use distilled water to top off. Check your antifreeze strength with a cheap tester to make sure you do not get the antifreeze to deluded.
Tester: http://www.ebay.com/itm/NOS-PLEWS-5-BAL ... rmvSB=true
If the pH level is below 7.0, you need to change your coolant. You can buy pH test paper to test the pH of the antifreeze and see if it is acidic. If the pH drops to low, the antifreeze will dissolve gaskets and metal from the water jacket and passages in the engine over time. Most people just change the antifreeze every 5 years.
