2005 Vibe - Front Brake Dust/Splash Shield availability
vandeda
Post by vandeda »
Good evening! The front brake dust/splash shields have rusted out on my 2005 FWD Vibe (base model). GM has discontinued them (part numbers 88970125 and 88970126). I have not seen any aftermarket units either. Are these really unavailable? Does anyone know of any other sources other than a junk yard?
petervivian
Re: 2005 Vibe - Front Brake Dust/Splash Shield availability
Post by petervivian »
Have you checked the parts on the same year's Toyota Corolla? These may be generic parts shared between these vehicles.
Should be able to get them for a Corolla/Matrix. I think RockAuto has them.
As zbyers said, here is a link:
http://www.rockauto.com/en/catalog/toyo ... plate,1628
If not a direct fit, these should be close enough that only minor modification would be required to make them work. At $19.70 for both front, it is worth a shot.
vandeda
Post by vandeda »
The Dorman shields work. I'm not sure why Dorman doesn't list them as compatible with the Vibe though.
