ETC Sensor
leaster1939
ETC Sensor
Post by leaster1939 »
Where is the ETC sensor located on my 2009 vibe GT
Re: ETC Sensor
On the 2.4L engine, the temp sensor should be located by the upper radiator hose where the hose attaches to the cylinder head. You may have to remove the engine cover and the air cleaner box. The temp sensor has a gasket on it and needs to be torqued to 14 lb-ft when installed so that the gasket seals.
