Hi there,
I just noticed recently that my 2wd 2006 Vibe is making a noise when shifting from Reverse to Drive. On level ground, in normal temperatures, and with the car completely stopped, when I shift from R to D it is making a metallic "clank/tink" when it shifts into Drive. It also makes a slightly less audible noise when going from P to Drive. There are no grinding noises and the transmission seems to be performing normally. Is this anything to be concerned about?
Thanks in advance,
