steady airbag light 2005==---
jamesmetairie
Post by jamesmetairie »
Hi Guys
2005 with about 112,000 miles on it.
never wrecked.
airbag light shines steady.
Would you say there,s a good chance a dealer can simply clear it and all will be well ?
Anyone know of an honest shop that can do it within 300 miles on new orleans ?
jamesmetairie
jamesmetairie
Re: steady airbag light 2005==---
BTW
the drivers seat belt usually just hangs when it is unbuckled.
deafanddiabetic
Post by deafanddiabetic »
OP, I'm also having an issue with my airbag light on constantly. Just showed up one day with no purpose, can't find a fuse for it, tried taking my negative battery cable off to no avail. Sometimes the car will run a few minutes with it off then it'll come on suddenly again.
But, in regards to your seatbelt, that's your seat belt mechanism probably getting old and tired, they aren't hard to replace.
MacGyver
Post by MacGyver »
Did you have the airbag recall work done yet, or get the letter from GM?
A common cause is the clockspring goes bad and connectivity to the steering wheel airbag is lost.
2009 Vibe Base
