Dash rattle
GT Guy
Dash rattle
Post by GT Guy »
Is there a service bulletin # for this problem??
Re: Dash rattle (GT Guy)
AFAIK, no bulletin, but most have confirmed it's the DRL relay module rattling...
Merzbow
Post by Merzbow »
I have one of those, it is coming from the right side of the gauge pods sounds like a sticking sorta rattle? -=Paul=-
http://www.cardomain.com/ride/541918-1999 Infiniti Q45t-2003 base Vibe (Rest in peace my love)-2002 Ducati Monster 620 Dark
Toasted7
Post by Toasted7 »
I have a dash rattle as well. Just started a few months ago and it's coming from the left side of the steering wheel, behind the storage compartment. If I open the up and push up against the top of the compartment, it usually stops, but if I let go... it will start "buzzing" a few seconds after that. It's really starting to (removed) me off (when I don't have my stereo cranked up that is). Anyone else have this issue or any suggestions for me to fix it???
Re: Dash rattle (Toasted7)
My dash rattle is from the top left , about where the light sensor is . It's not the sensor, becuase I took that out, made no difference, so I put it back. Seems to only happne when cold, so hasn't been a problem much lately. Can get it to stop if I push down on the leading edge of the dash, right by the windshield in the left corner.I will probably take it in to a dealer to get it fixed before the warranty runs out.
P POPPR
Post by P POPPR »
quote:I have a dash rattle as well. Just started a few months ago and it's coming from the left side of the steering wheel, behind the storage compartment. If I open the up and push up against the top of the compartment, it usually stops, but if I let go... it will start "buzzing" a few seconds after that. It's really starting to (removed) me off (when I don't have my stereo cranked up that is). Anyone else have this issue or any suggestions for me to fix it???Exact same situation here. So far we only have 1300 miles on the car. After we put on a few more miles on it we plan to have the dealer care for that noise and any other things that come up. So far that noise is the only complaint.
2004 Abyss MonotoneMoon & Tunes17" Aluminum Wheels/TiresAnti-Lock BrakesPower GroupAutomatic15% Tint, Rear WindowsHidden Hitch
Re: Dash rattle (P POPPR)
Good luck. Had my car @ the dealer 3 times for rattles. The last time I took the service guy on the road, he acknolwedged them, and I STILL got the car back with "NPF: NO PROBLEM FOUND" or "UNABLE TO REPRODUCE CUSTOMER CONCERN" bullsh*t on it...
DeClerq
Re: Dash rattle (ragingfish)
Post by DeClerq »
We've got one as well, though it seems to originate from the right side of the dash and only when accelerating. Haven't really investigated it yet, but will probably get it checked out when I have the alignment issue taken care of.
'09 Mazda5 Grand Touring'04 Vibe - M&T, Power Package, Protection Package
northvibe
Post by northvibe »
DeClerq - did you find out what it was? wow this post is old but, i get a weird rattle/vibrating when i accelerate, ill have to investigate where it is this week. I know its either in my engine compartment or far into the dash.
Summer
Post by Summer »
If you have a mysterious "dash" rattle and can't locate the source, check the map lights in the rear-view mirror.
Atomb
Post by Atomb »
i've become quite adept at my 'kung-fu dash smack' accuracy.i find a quick jab or an upper-cut to specific locations does a good job of fixing rattles...
mcgusto82
Re: (Atomb)
Post by mcgusto82 »
my radio bezzel likes to vibrate/hum at high RPM.i put some electriccal tape around the crips. it's muzzle it down.
thermometer
Post by thermometer »
Sometimes the rattle is from the silver trim around the gauges
