2009 pontiac vibe 1.8l 2zr-fe 11-08 build date. Found some at monkeywrench racing. Says that they fit 1ZZ-FE, 2ZZ-GE, 2ZR-FE. I emailed them about this because I can't find anything that says that they use the same size head bolts. I also asked what the length of the head bolts was ....they couldn't tell me the length.
I talked with the parts guy at GM dealership he can't even get any. He did find ES72249-2 head bolts, they are for toyota, toyota truck L4 2.4L DOHC Eng 2001-09. These bolts are 5 5/8 in length. The bolts I removed from my motor are 5 13/16 in length.
Will 3/16 of a inch shorter be an issue. Can I use these head bolts. I don't want to order from MWR without knowing the length and not finding anything saying the 3 engines use the same bolt.
