Blower motor issue
underground260
Blower motor issue
Post by underground260 »
I'm having an issue with my hvac blower. It keeps wanting to go out. Messing around with the wiring harness it wants to kick on. It's working so far but just curious if I need a new motor or change out the terminal which I can't find. Thanks
jayoldschool
Re: Blower motor issue
Post by jayoldschool »
1st suspect would be the blower resistor module. I think everyone with a VIbe has had it replaced (or needs to).
When the blower does run can you change the speed of the blower, or in other words, does the blower speed change when you switch the fan speed?
