Evap Problems
HPilot
Evap Problems
Post by HPilot »
On my 2010 Vibe, 2.4 li, Fwd the vsc, service engine, and anti skid lights flash
Garage says it is an Evap problem.
The solenoid on the canister checks out. Opens and closes with 9volt battery.
After disconnecting the car battery, alarms cancel out, but come back in a few days.
Possible small leak?
How do I further diagnose?
MacGyver
Re: Evap Problems
Post by MacGyver »
Need the codes that are triggering the check engine light (CEL). VSC and traction control disable when CEL is on.
2009 Vibe Base
HPilot
Re: Evap Problems
Post by HPilot »
I believe the code was P0133, or P01133.
The GM dealer had to really look o find the code and it
Basically comes back as Evap leak.
Re: Evap Problems
Here is a link on this board about the PO133 code:
viewtopic.php?t=21890
I think your communication got mixed up somewhere. What your talking about and that code do not really go together.
HPilot
Re: Evap Problems
Post by HPilot »
Jolt
The code is P043e an orifice low flow leak.
Does this point to one of the valves or is it one of the hoses leaking?
Re: Evap Problems
HPilot
Re: Evap Problems
Post by HPilot »
Thanks again, read the links. Guess I was to lazy to think it thru.
Also an across the following link, found it interesting.
https://m.youtube.com/#/watch?v=oeNqJtwmFw8
Thanks again.
