Loses power when going up hills...
ehoff121
Re: Loses power when going up hills...
Post by ehoff121 »
When you step on the gas pedal, you use more air, more fuel, and more spark.
Have you checked/changed the air filter? Has the fuel system ever been serviced? Is the alternator/battery original?
If it were transmission, the RPMs would likely increase not bog down.
Another potential cause could be seized brake calipers- check the brake pads for excessive wear.
MacGyver
Post by MacGyver »
Is the check engine light on? Clogged injectors?
2009 Vibe Base
Plugged exhaust system, bad catalytic converter. All kinds of things can cause power loss. With out more information from testing, it's only guessing.
If the air can't get out, it can't come in. Check engine vacuum at idle. Google about it>
ehoff121
Post by ehoff121 »
One of the nice things about this site is that nobody will demand that you turn it in :D
We're just a bunch of helpful folks!
gtv237
Post by gtv237 »
DRVibe wrote:So embarrassing.... Air filter changed and wow it runs without a hitch. Thanks for the help!
Now, if you'll excuse me I have to go find my "Man Card" so I can turn it in... :roll:
Wow I would like to see that old air filter. I've never seen one so bad that it causes drivability problems.
