Pos or neg horn connection to steering wheel switch?
BenWA
Post by BenWA »
I ordered a set of Hella Sharptones (yellow). I will be installing them sometime in the next week. However, I see that I need to know if the horn is connected to the steering wheel switch with positive or negative. How is the 03 Vibe's horn connected?
EDIT: I'm now pretty sure it's positive (the wire that connects to the stock horn is what is best to feed from for the Hella's relay) but I'll still wait for a reply.
2003 Vibe Base A/T
Re: Pos or neg horn connection to steering wheel switch?
Here is the horn wiring in the pdf file that is attached.
026hs.pdf
Horn wiring 2003
(14.13 KiB) Downloaded 193 times
BenWA
Post by BenWA »
Yeah it looks like the wire at the factory horn is positive, not ground. Ground is fed from the mounting bracket.
Thanks.
2003 Vibe Base A/T
