2007 Pontiac Vibe
my skill: intermediate
Car starts and runs fine until... battery not charging, battery voltage 12.6v , when running doesn't change, no change with increase with RPM
Slowly battery loses charge and fails and car quits...
Battery holds charge via external charger
ALSO:NOT Working No cluster lights or instruments, no radio , no signal lights, no A/C, no day time running lights, no blower fan
Working: hazards lights, cig lighter, dome light, brake lights, head lights, wipers,
What I have done: inspected wiring/grounds...no obvious issues
replaced alternator fuse (original looked fine)
replaced fusible link (original looked fine)
checked all fuses in both fuse box... all good
charged battery/ check voltage (after charge 12.6 also running 12.6 then degrades)
I also looked at 2004 power source electrical diagram....nothing seems to match if it is an issue with alternator fuse brake lights shouldn't or cig /lighter but they do..... this could be just the wrong diagram... if any one has one... send it along
So any thoughts? alternator? (its relatively new) mystery fuse issue? wiring from alternator to battery / fuse box is bad/ECM
Cool
G
