Removing EVAP, any computer tuners here?
samsonite
Post by samsonite »
I want to completely remove the EVAP system on my car and just have it vent to the atmosphere. Is there anyone here who could remove the codes from the PCM so they don't appear?
circuitsmith
Re: Removing EVAP, any computer tuners here?
Post by circuitsmith »
What do you expect to gain by doing this? Trying to avoid fixing a broken EVAP system?
Besides more pollution you'll decrease your MPGs slightly; and your gas will evaporate and go stale faster if you don't allow the tank to build slight pressure.
2006 Matrix 5-sp
samsonite
Post by samsonite »
circuitsmith wrote:What do you expect to gain by doing this? Trying to avoid fixing a broken EVAP system?
Yeah, fix the problem by removing it. :lol:
I guess i could fix it... Where to start? No check engine light/ no codes. Should I replace the charcoal canister/box? Check the pressure valve?
circuitsmith
samsonite wrote:Where to start? No check engine light/ no codes.
So what's the problem? Symptoms?
2006 Matrix 5-sp
samsonite
Post by samsonite »
Gas pump clicks off constantly. It's really hard to fill. It clicks off nearly 40 times before i get to the full mark. Just bought this Vibe with 63,000 miles
Chiadog
Post by Chiadog »
Have you inspected the systems components? I'm guessing it won't be this easy to diagnose! But should be an easy diagnosis for a mechanic who regularly works on Corolla's.
viewtopic.php?f=12&t=45202#p512518
samsonite
Post by samsonite »
Chiadog wrote:Have you inspected the systems components? I'm guessing it won't be this easy to diagnose! But should be an easy diagnosis for a mechanic who regularly works on Corolla's.
HAHA! I'll take a look at it maybe this weekend.
You can't alter the PCM. You'd have to get a stand alone system for a mere $1300, and then tuning is $400-800 usually. A piggyback wouldn't touch the EVAP system, and I'm not sure a stand-alone would, either, not without massive amounts of modification.
Chiadog
Post by Chiadog »
I found this simple test for a plugged charcoal canister on YouTube! You may be able to do this without removing the canister. I'm sure there are other "youtubes" concerning diagnosis of EVAP symptoms.
https://www.youtube.com/watch?v=0hdY29nkXiw
