The only reliability issue more common in the earliest Vibe years was the 5 speed manual transmission. If you avoid those, then any 03 or 04 should still be reliable, of course, unless its been beaten to death or otherwise abused/ neglected. My first Vibe was an 03 with a 5 speed tranny. I got 288K miles out of it, and replaced it 3 years ago with an 03 automatic that had 157K miles, now at 214K miles and fine.
Other than the 5 speed tranny, there shouldn't be any particular critical reliability issue with an 03/04. You'll have standard kinds of issues with any 12 year old car. Tires/brakes, battery, fluids, etc. Don't know if its particular to a vibe, but after 12 years, you may need to replace some gaskets, such as the valve cover, timing chain tensioner, or perhaps intake manifold gaskets. Easy enough to do yourself, even for less than expert mechanics.
A common failure due to bad design is in the motor assembly that switches between fresh air and recirculate. I don't know if thats more common in the earlier years, of just common in the 03-08's
Depending on the mileage and a lot of other factors, the car may need or soon need a replacement catalytic converter. My advice on that one is to buy or borrow a code reader, and hook it up to the candidate car. Depending on the code reader, it may give a not ready status, indicating that the diagnostic codes have been reset recently enough that the car hasn't had time to run all of its self tests. This almost bit me once, I bought a used truck, my code reader gave the not ready status, and the dealer said it was because they had reset the computer by taking the battery out to clean the terminals. 100 miles after I bought the truck the check engine light came on with the code for catalytic converter, and I made them fix it. Can't say for sure they tried to hide the bad cat from buyers, but it sure seemed that way to me.
In the first generation vibes, My vote would be for an 04. The 03's/04s have a minor cosmetic only difference in the front grill from the 05-08s, I prefer the earlier one. The 03-04 Vibes also came with cross bars in the roof rack, which may or may not be important. Also the 05-08s dropped the power outlet in the console between the seats that was standard in the 03-04, and the taller console armrest in the 03-04 seems to be overwhelmingly preferred. The 03-04 also have a wire throttle, 05-08s have electronic throttle. Throttle reliability hasn't been an issue, but perhaps for only nostalgic reasons, I prefer the cable throttle. The 03 had an all red instrument cluster, I think the 04 and up red and white cluster is better, so that's why I say an 04.
Even if your budget is small, the cost of a car is still a major commitment. On my first one, I went for price, and got one that didn't have power windows/locks or cruise control. My current one does have those. I feel those things are worth having, you may or may not, but if you think you will want them, get a car that already has them, its probably not going to be worth adding them later
Caretaker wrote: I rarely get my questions answered and I've been on here nearly since inception; so join the club.
I'm reluctant to answer your questions on the 2nd gen vibes, I only have experience with the 1st gens
vibenvy wrote: If you're on Facebook, join the GenVibe group on there as it is much more active nowadays.
You're right, forum activity here really dropped when the genvibe group formed on facebook. We used to have a hectic off topic forum, and even had a chat server set up with regular chat sessions, but that's now how it is here right now. My brother was an early facebook member, I have his counter example of social media addiction to where I never signed up. Do you talk about Vibe stuff there, or just share pictures of meals?
