SCCA Autocross El Toro 3-19-16 & 3-20-16
Discussions about legally sanctioned general motorsports events
B14CK_H4WK
Post by B14CK_H4WK »
Derf
Re: SCCA Autocross El Toro 3-19-16 & 3-20-16
Post by Derf »
Nice, video says you made a few minor adjustments. Everything work out the way you wanted?
Great use for an abandoned airport.
2005 #10,524 Neptune Vibe "Bandit" Auto, Moon & Tunes 238k :D
1991 Pontiac Bonneville 3.8L "Granny's Whip" 142k (33nd Anniversary :o )
B14CK_H4WK
Yes the car really really handles 100% better by just putting the caster all the way back on the camber plates which also added some negative camber. I finally felt like the adjustable suspension came in handy, since i was able to change camber within 10 minutes while at autocross. The front wheels sit about -3 camber, 0 toe and the rear is about -1.5 camber. The car literally drove itself after that and felt alot tamer to drive. I was able to drop the PSI a little bit in the front wheels and they also didnt heat up as much in the front after adding the camber. After having this setup now for about a month i can say my tires are finally wearing out evenly lol. The car is always in corners and loves it.
