Help? Maybe y'all gurus know?
Demonicvibe
Post by Demonicvibe »
I have a 2003 Pontiac Vibe the stereo domt work and the interior lights key fob will not work and now my dash lights are starting to go out they come on the dash lights come on when I start the car and I'll stay on for about a minute and then go off soon but have any ideas on how to fix this issue.
2003 Pontiac vibe lava red on 17s
Life is too short to drive an automatic
sideshowalan
Re: Help? Maybe y'all gurus know?
Post by sideshowalan »
Does the car start and drive OK?
Lights and radio stopping soon after starting sounds like a failing alternator, but it would cause the car to stall out too.
2008 Pontiac Vibe
2008 Toyota Sienna XLE
Demonicvibe
No the car drives fine.
Welcome to GenVibe Demon man. Just curious as to the mileage on this Vibe. Do you have any history of what was done to it in it's past 12-13 years? Has the transmission been replaced yet? Good luck with these minor electrical issues and keep us posted as to what you find
Mark
Post by Mark »
Kinda sounds like a bad ground.
I think Mark has it right - a bad ground. That is one of the things all these parts have in common. It looks like voltage is back feeding through to other systems to try and find a ground.
When you open the rear hatch or rear hatch window, does the the rear interior light come on?
You are going to have to get a wiring diagram for your car and a voltmeter to start tracing each wire out that is involved to find where the broken wire, bad ground, or bad component is at. That is why shops get paid by the hour to trouble shoot these kind of problems.
