New Vibe Maintenance
cjnoyes
Post by cjnoyes »
I just this week bought an 03 base automatic with 124K on the odometer. I already switched out the O ring on the timing chain tensioner, solving a small oil leak, which was the only problem I was able to detect with the car. I am wondering what other maintenance I should do around this mileage as preventative maintenance, or to improve performance.
Thanks!
ehoff121
Re: New Vibe Maintenance
Post by ehoff121 »
Welcome to GenVibe!
There's lots of maintenance info in the Maintenance and Care section of the board.
Off the top of my head, you'll want to check/replace the following:
Brake Pads & Shoes
Engine oil
Transmission Fluid
Brake Fluid
Radiator Coolant
Power Steering Fluid
Engine Air Filter
Cabin Air Filter
EDIT: Positive Crankcase Ventilation Valve (PCV)
Mass Airflow Sensor (clean)
Throttle Body (clean)
Idle Air Control Valve (IACV) (clean)
Oil Control Valve & Filter (OCV)(clean, though some replace the filter)
You may consider changing the Intake manifold gasket as they tend to get leaky and cause rough idle- you'll have the throttle body off, so you can clean it and the IACV in the same session.
That should keep you busy for a while... :)
what ehoff said.
Also check with a GM dealer if all the recalls have been taken care of.
PCV typically stands for Positive Crank case Ventilation valve, but pollution control valve sounds better.
ehoff121
Post by ehoff121 »
vibrologist wrote: PCV typically stands for Positive Crank case Ventilation valve, but pollution control valve sounds better.
I'm showing my age here. Back in the day, that's what I was taught PCV stood for. :oops:
Correcting the original reply...
Welcome to GenVibe! Congratulations on your "new" Vibe! We love pictures around here, so please post some when you get a chance ;)!
