Aftermarket Sheet Metal
MrWhoopee
Post by MrWhoopee »
I will soon be faced with replacing a front fender. Just wondering if anyone has experience with aftermarket body parts. I'm seeing quite a range of prices, which I assume means a range of quality. Would appreciate input from those who've been there.
Craig
'06 Matrix Base AWD
Derf
Re: Aftermarket Sheet Metal
Post by Derf »
Depending on if you are a shop will be doing the work, you could get a panel from a salvage yard. The paint will likely be faded just enough to match your current vehicle and the metal and mounting points will be OEM. What price range and color are you working with?
2005 #10,524 Neptune Vibe "Bandit" Auto, Moon & Tunes 238k :D
1991 Pontiac Bonneville 3.8L "Granny's Whip" 142k (33nd Anniversary :o )
I would also recommend getting a used panel like from www.car-part.com if you can find one local. My friend's shop put a used door on my son's 06 and it worked just great. Can't even tell it was used except it does not have the VIN number on it. He did tell me that they use Certifit parts when they end up using aftermarket parts, as they've found they tend to fit the best.
Good luck!
thebarber
Post by thebarber »
I've got a good driver side fender that I'll be selling cheap. In with a Canadian dollar in a slump, it might be worth it to ship
OP owns a Matrix (INFILTRATOR!), so I'm afraid you won't be making this sale, Barber ;)
