Engine above 3000 shuting on/off
Pawel
Post by Pawel »
Hi all. I got a quick question. Does anyone know what might be wrong if engine above 3000 rpm acts like "there is a fuel shut off"? From 0 to 3000 rpm everything is ok, then as soon as rpm needle goes beyond 3000 rpm it shuts on and off (similar when fuel shut off engages to prevent over reving the engine).
2003 VIBE GT ABYSSMODS:AEM CAI PHILIPS BLUEVISION
AKLGT
Re: Engine above 3000 shuting on/off (Pawel)
Post by AKLGT »
when is this happening? there is a rev limiter on the vibe if the engine is not warm enough. this was discussed in a previous thread about a month ago. if it's when you first turn the car on before the engine warms, then it's the limiter. if not, then ..... you may have a prob.
AKLGT1998 Subaru 2.5RS
Sub-Vibe-R
Re: Engine above 3000 shuting on/off (trdvibe)
Post by Sub-Vibe-R »
At only 3000 rpm!!! It looks like your car have a problem. Even if mine is cold, I can rev. my base up to 6400 rpm before getting the cut off.
slbpsi63
Re: Engine above 3000 shuting on/off (Sub-Vibe-R)
Post by slbpsi63 »
The 3000 rev limiter is only on the 2ZZ engine. I test drove a celica and that damn rev limiter kicked in for the first 5-10 minutes. Anything longer than that I would get my engine checked out.
Base Vibe, Shadow Monotone, 5sp.
goodvibe
Re: Engine above 3000 shuting on/off (slbpsi63)
Post by goodvibe »
There is no 3000rpm rev limiter though this motor will do things like that to protect itself. It won't hit lift when cold. 6000rpm. Check your MAF sensor. It may be oiled from your CAI filter creating an overly lean mixture and triggering the knock sensor or other failsafe. Clean it and reset the ecu. It may be something else but it's a quick and easy first check for a common issue.
Pawel
Re: Engine above 3000 shuting on/off (goodvibe)
Post by Pawel »
quote:There is no 3000rpm rev limiter though this motor will do things like that to protect itself. It won't hit lift when cold. 6000rpm. Check your MAF sensor. It may be oiled from your CAI filter creating an overly lean mixture and triggering the knock sensor or other failsafe. Clean it and reset the ecu. It may be something else but it's a quick and easy first check for a common issue.what would be the best way to clean it? what should I use to do it?And the engine behaves liek that when at normal operating temp.
Pawel
Post by Pawel »
by the way, where are the ECU fuses? and, where are fuel pump fuse or relay?
robdog
Post by robdog »
Problem there. See dealer for details.....
03, Abyss monotone GT, 6 disk changer, moon and tunes, Cargo mat/nets, power package, side airbags, AEM Short Ram Intake, Borla exhaust , 35% tint all around, F1 strut tower brace, debadged, 17" Excel rims w/ federal ss595 tires.
goodvibe
Post by goodvibe »
2 in the fuse box labeled EFI. One is correct but pull them both or just disconnect the battery.
