Yada Backup Camera wth 5" display
jake75
Post by jake75 »
Bought at Costco $119.99 minus $20 instant rebate. Got it installed last week by a family member. Wired it so it is on when the lights are turned on as I wanted to be able to use it beyond just when in reverse gear, and I think that was easier anyway. Hope the life of my headlights are not too adversely compromised but I only drive the Vibe about 6,000 miles a year so that should be o.k. My major disappointment is that the lens is very wide angle, even worse than the right side view mirror in terms of objects are closer than they appear. Would not have purchased if I had realized that. Still, it may be helpful in monitoring vehicles that are passing on my right and on my left as well as those object/persons behind me when backing up. Also, I wish the monitor would fit in the same holder as the GPS. Their monitor and suction mount has a different connection.
Re: Yada Backup Camera wth 5" display
Jerome, Just curious as to what this install looks like. Pics please. Is the display on all the time or only when in reverse? Model number (I'm a Costco member so may look into this myself). This is something that I plan on adding to both of our 2009 Vibes somewhere in the future. Thanks ................... Tim
jake75
Post by jake75 »
Working from my iPad - can't seem to attach photos. Says file too large. Send me an email schindlerjerome@gmail.com.
jake75
Post by jake75 »
Here is a link to one sold at Autozone - it is a 4.3" diagonal screen. Th Costco one (2nd link) is 5" diagonal.
http://www.autozone.com/safety-and-secu ... 77344_0_0/
http://letsyada.com/index.php?id=digita ... CRIPTION-0
Mine is wired so the camera is powered when you turn on the headlights.
Jake's 75 equipment & setup :D
jake75
Post by jake75 »
COSTCO FLYER received today eff. 10/1/15 through 10/25/15 has this Yada 5" Backup camera again for $99.99.
As stated earlier, it seems to give a very wide angle view - like the right hand outside mirror, objects are closer than they appear on the screen.
[Also Mobil 1 Motor Oil 6/1 QT $10 off. 5w-20 is listed. ]
