No moonroof, no maplights? '07 Base
calivibes55
Post by calivibes55 »
Hello all, I have a 2007 Vibe base (manual locks, manual windows) and have always been annoyed with how dim the front cabin is at night; the dome light is too far back to be much use up front.
Reading up on LED dome light conversions I read that non-sunroof vibes were supposed to come with a rearview mirror with maplights?? This would be so useful.
1. Was my base trim Vibe supposed to come with the maplights? I bought it used so it is possible the mirror is a replacement
2. If it was, I assume the wiring is up there to plug into. If not, is the wiring there anyway so I could do a plug and play replacement?
Thanks!!
Fever
Re: No moonroof, no maplights? '07 Base
Post by Fever »
I also have a base '07. Manual door locks, crank windows, no moonroof. Plain old mirror with no map lights. Looks stock to me and I found no wire harness for the fancy mirror when I removed the headliner.
Check out my thread where I added leds up front to improve my lighting. viewtopic.php?f=18&t=44651
Fever
'07Vibe '13FR-S '99Ranger
Earlier Vibes w/o sunroof did come with the rearview mirror with map lights but I suppose they must have dropped that feature somewhere along the way to save a buck.
An aftermarket replacement auto-dimming mirror with map lights may be a nice upgrade.
calivibes55
Thank you very much Fever, that's a great install and tutorial, I'll be studying it!
ColonelPanic, agreed, and whether I go that route or install LEDs like Fever either way I'll be running power to the top front of the car. Will take some pics as I go.
GaryG92 on here encountered the same thing on his base Vibe. He thought the seller just put a cheap replacement mirror on it, but it does not have the electric plug or wiring for it. So I grabbed a mirror with the lights and pulled the wiring harness that ran down the A pillar and behind the dash for him. Don't know if he hooked it up yet.
