Spare tire pressure
Mark
Spare tire pressure
Post by Mark »
Just a reminder to check your spare tire air pressure a couple times a year. I saw that mentioned on another forum and went and checked while I was thinking about it. Should be 60psi
04 Vibe: just a couple psi off, but it had been mounted when my daughter had a flat, and I think the shop aired it up when the put it away.
08 Vibe: 40psi
12 CR-V: 40 psi
00 Corolla: 7 psi
It's a pita because they're mounted upside down and I had to move all the stuff that gets packed in the empty space on top and around the spare, but it would be a much bigger pita to have a flat and find that the temporary spare was flat too.
ctgottapee
Re: Spare tire pressure
Post by ctgottapee »
Nothing like starting to change a tire to find you have a flat spare out in the middle of no where! [let the profanity rain downeth!]
jayoldschool
Post by jayoldschool »
Just one more reason I carry a compressor with me.
I try to check our spares once a month. I don't think they've ever gotten below ~57 PSI.
