I'm planning on buying a Dayco belt with a 3 year warranty for about $24, instead of the Duralast with 1 year warranty for about $16-17. Is it a good idea to go with the better belt?
I don't really have any questions about installing the new serpentine belt. Seems pretty straight forward, and I have a few routing diagrams saved on my phone just to make sure I get it right.
My main question is about the belt that seems better, if I should get it or stick with the cheaper one, and if there's any additional preventative maintenance I should do. Should I change the tensioner pulley even if it seems to be fine? (I haven't checked into its current quality) But I saw the pulley isn't very expensive, maybe another $16. I was curious after seeing a water pump for about $45, and then I watched a video on changing that out. Pretty simple looking, remove belt, alternator, 6 bolts in the water pump and that's about it. My current water pump seems to be fine, no over heating problems and I haven't noticed any coolant leaks, but I'm not sure how long they typically last.
Additional info: 05 vibe base, auto tranny (I think this is all in my sig
