Replacing Interior Dash Part
NestleQuik37
Post by NestleQuik37 »
Hey,
I have been in search of a part for my 2006 Vibe (1.8L manual), its number 10 in the picture. (the power outlet face plate)
A while back I was taking it off to check how deep the compartment went, to see if it could fit my CB radio, but in the process I broke off one of the clips that holds the plate on and it sticks out a half inch unless I'm holding it in.
I've tried hot glue and super glue and a few other things, but none have held. Does anybody know where I could buy a new face plate?
vibe dash blowup diagram.gif (7.82 KiB) Viewed 1636 times
Re: Replacing Interior Dash Part
I think you may have to try a salvage yard.
I also discovered when the dealer broke off the clips from the radio bezel during a recall repair, this plastic does not like to be glued back together. :?
This might still be available at the dealer if you're willing to spend some extra bucks. I was able to order the radio bezel plus the shifter surround trim and HVAC knob label (#3 and #9 on this diagram) new from a Chevy/Buick dealer as of December.
I'll have to be extra careful when transplanting this piece when I go to replace the shifter trim once it warms up!
Neptune/primer/rust
'21 Elantra Limited 2.0L/IVT
It is Toyota part number 55449-01040 Googling that turns up a number of on line sources, seems in the $13 area (and likely + shipping) A junkyard would likely be cheaper, but would take a little more time/effort, and you likely won't know whether a junk yard has one or not until you go there and possibly walk the yard
